Thats your cars name, you cursed it, and its depressed because you keep driving big displacement saloons and hondahhhhs lol
Good work getting it on the road, saw you in it the other day, get it finished so we can go racing
Graeme
JJ wrote:Ashman, it was doing 7K+ in 5th when it let go
Just curious, can anyone let me know what speed this is?
JJ wrote:Quigonjay wrote:has the crank been worked on before jj?
looks a little like this one
Jay> That looks great.
any history on it.
? Boost
? ally crank pulley
Or did he stick in 1st gear at 90
.the only thing I can promise for sure is slow progress.
just have this niggling thought that if I rip out the wiring, then the car will never get out of the garage again.![]()
ashman wrote:I wouldn't worry too much mate unless you're planning to rev to 10k.
They normally balance the crank on it's own, then with the crank pulley, and then with the flywheel as well, and then with the clutch cover as well.So your crank will be balanced in it's own right.
Just get a stock crank pulley, get it balanced on it's own, and you'll be fine I reckon.![]()
Either that or rip the block apart again and get the whole thing re-balanced with a stock pulley
