are the SC brake components the same as the Mk.1b components
I need to change them this week so am in the market for pads and discs.
I notice ebay have brembo discs and pads for the mk.1
Cheers!
coanda
coanda wrote:I found another set of fronts on ebay- lets see how we get on with that.
But yeah- if that fails it'll be brakes int.
as fensport are either very expensive or very very expensive.
MartG wrote:You could always try and find a set of ST165 Celica twin pot calipers- they are a direct fit and even fit under the 14" wheels
rikster wrote:celica gt st202calipers fit im going to try the discs when i get the studs out.
Keri-WMS wrote:rikster wrote:celica gt st202calipers fit im going to try the discs when i get the studs out.
The Celica single-pot caliper has about 25% more piston area(front bias) for what it's worth, also remember that the Gen 6 Celicas have a 55mm bore not 54mm like the AW11.
Hope that helps!![]()
rikster wrote:Keri-WMS wrote:rikster wrote:celica gt st202calipers fit im going to try the discs when i get the studs out.
the celica hub 54.2mm
