[Mk2] [NA] Looking for a FPR recommendation -3SGE
RST
Post by RST »
Just doing some homework at the moment. My gen 4 3SGE is kicking out somewhere near 220Bhp (fly) at the moment but I think I'm finally going to fit my itb's. Speculating at the moment but another 15-20Bhp is probably feasible with the set-up fitted.
I might need an aftermarket uprated FPR -anyone got any ideas for a reasonably priced suitable one, say one suitable for 3SGE up to 240Bhp (not sure exactly how it works with sizing these).
Got a few long trips to make next week and I can look at my injector duty cycle through my Link Display to see whether one is going to be needed or not. If I need one I can pick it up ahead of fitting them to save time later on.
Anyone explain to me the relationship between % loading and pulse width as I can see both of those? Sticks in mind that injectors want to be somewhere near 80% capacity to work properly?
Davezilla
Re: [Mk2] [NA] Looking for a FPR recommendation -3SGE
Post by Davezilla »
I have a Sytec rising rate one. Aeromotive do a few also, might be worth looking at them?
Protok
Post by Protok »
I personally have been looking at the SARD Fuel Pressure Regulators for my build. They seem to have a good rep and a wide enough pressure capability.
Nod
Post by Nod »
Turbo Smart !
Protok
Post by Protok »
Nod wrote:Turbo Smart !
Just had a look; even more expensive than the SARD :shock:
T.F.S.
Post by T.F.S. »
would be fine on an FSE, SBD have been using them for years without issue on N/A applications
Nod
Post by Nod »
There's a very good reason for that ;)
T.F.S.
Post by T.F.S. »
if they both hold fuel pressure i cant see any good reason TBH
on my modded turbo i used a £250 aeromotive but on N/A its a waste of money
Protok
Post by Protok »
T.F.S. wrote:if they both hold fuel pressure i cant see any good reason TBH
I agree with you, as long as it doesn't burst from use it should be okay.
T.F.S. wrote:On my modded turbo i used a £250 aeromotive but on N/A its a waste of money
But why are they a waste on an N/A?
An N/A requires more careful thinking at the least than a turbo, requires more accuracy than a turbo ever needs. Of course remembering that these aren't 150hp 3SGEs.
T.F.S.
Post by T.F.S. »
have no idea what you are talking about mate or rather you dont
