[Mk2] [NA] DIY/Free Modifications?
rayroocroft
Post by rayroocroft »
hey guys are there any DIY modifications available for the MR2 that dont cost an arm and a leg? just thought id ask from curiosity as for my fiesta mk5 there were plenty of interchangeable parts from the other cars in its year from ford. many thanks!
Razor04
Re: [Mk2] [NA] DIY/Free Modifications?
Post by Razor04 »
Swap your N/A emgine lid for a raised vent turbo lid, you can pick em up on here in every colour going for a few pennies
C50
Post by C50 »
there's a thread with cool mods peeps have done, some costing little to nothing
Richie86
Post by Richie86 »
Here's a quick list of what i can think of.... Although some may argue these may not be 'cheap' and not to everyone's taste (or mine :-# ) but they are examples
1 ) Swap Cloth Seats for Leather Seats
2 ) Swap Cloth Door cards for Leather Door Cards
3 ) Lazy Eye Kit
4 ) HID's
5 ) Rev 3 Rear Light Conversion
6 ) N/A to Turbo Engine LID
7 ) Bulb - LED Dial conversion
8 ) Bulb - LED Heater panel conversion
9 ) Audi LED Style Side Lights
10 ) Tint Spray On Rear Lights
The following are interchangeable and fairly cheap
1) Nuts
2) Bolts
3) Light Bulbs
:D I needn't go on lol
Plus as said above there are plenty on the site, it just depends how good you are with DIY'ing
C50
Post by C50 »
colour coded headlight cowling 8)
kayjay0_7
Post by kayjay0_7 »
Toyota Yaris washer jets
Rossi
Post by Rossi »
I added a 79p switch from maplin to my headlight control box.
Problem is when you have sidelights on then flash your headlights, once the light has gone off the pop ups remain up but turned off!
This switch means they pop back down again when set to off or work in the standard manner when set to on
alanmr2turbo
Post by alanmr2turbo »
Rossi wrote:I added a 79p switch from maplin to my headlight control box.
You got a walk through for this Mod?
Rossi
Post by Rossi »
I knew I should have taken more pictures!
If you look into the connector on the headlight retract box you will see the pins are numbered. You want pin 6.
Now open the headlight retract box and on the reverse of the connector I snipped where the pcb joins to pin6.
Now solder a wire from the pcb to the switch.
Then solder a wire from the reverse of pin6 to the switch.
The switch just acts to break the connection between pin6 and the pcb.
I used a dremel to cut a hole in the headlight control box and some mini files to get it the right shape for the switch to fit in. The switch is a mini rocker from maplin 79p.
I soldered the wires at the retract box end and used crimps to attach at the switch end.
JohnnyC
Post by JohnnyC »
Think that was my first mod :)
Razor04 wrote:Swap your N/A emgine lid for a raised vent turbo lid, you can pick em up on here in every colour going for a few pennies
Not cheap unless you can get one in your colour.
Best mod I did was the folding mirrors 8)
Definitely not cheap though #-o
djpkins
Post by djpkins »
Rossi....thats a pukka self mod...don't suppose you know how to make them "mexican wave" , that would be real trick.
Jaspa
Post by Jaspa »
Wash and Polish :thumleft:
I asked God for a bike, but I know God doesn't work that way. So I stole a bike and asked for forgiveness.
Goldy
Post by Goldy »
One thing that I think makes a difference is getting the clear front and side indicators, makes the car look soo much more modern in my opinion.
Another thing you can do which makes a big difference is colour code the side strips and sills. 8)
kayjay0_7
Post by kayjay0_7 »
Here are another three
1) single side vent modification
2) mesh in side vents
3) mesh in front bumper
Tiamat
Post by Tiamat »
Keep the N/A lid - its lighter! :thumleft:
dansREV2turbo
Post by dansREV2turbo »
thought the turbo one was lighter with the top being some sort of plastic/fibre glass?
Adam86
Premium Member
Post by Adam86 »
Turbo lid is lighter if you remove the under tray/rain shield thing.
Ive done this to mine it lets so much more heat out. Just not so good when it rains lol.
HighwayStar
Post by HighwayStar »
What used to be a blanking plate in my heater control, where others have their A/C control buttons, now functions as an independent switch controlling my aerial so I can leave it down when listening to CDs and stop my 2 looking like a radio controlled toy.
Add a bit of paint detailing to distinguish your car as well, individual, cheap and easy.
R.
Ian86
Post by Ian86 »
HighwayStar wrote:What used to be a blanking plate in my heater control, where others have their A/C control buttons, now functions as an independent switch controlling my aerial so I can leave it down when listening to CDs and stop my 2 looking like a radio controlled toy.
R.
Have you got a wiring diagram on how u did this? and are you using a non standard radio? im looking at doing this when i get a working aerial
HighwayStar
Just find the aerial power and splice a switch in. The blanking 'plate' needs to be cut down and its internal plastic moulding cut out (careful with the stanley knife!) then in my case we just glued inside it one of the duo of A/C buttons from another unit. Of course you could put a switch anywhere but this way there's nothing apparent.
R
PS. If you look at the interior pic in my garage the old blanking 'plate', now working button I'm referring to is directly above the knob for adjusting the fan strength on the heater control unit.
