The old setup is a bone stock 540cc oem everything.
The new setup is
Bosch 044 external pump
AN-08 fines
Aeromotive FPR
ATS TFFR
and 1200cc injectors.
I have reduced the Master injector pulse width from 10ms down to 8ms and the fires up and runs fairly well.
What i need to do is drive the car to SRR, 85 miles away, for a re-map.
Can anybody see any problem with doing this? Could i do damage to the engine in any way? is there anything else i could adjust in the EMS to reduce the risk of damage?
Also, being as i do not have a wideband, i dont know my AFR's so as am trying to stay away from going lean, there is also the possibility of going Rich! Would it be a good idea to take some fresh oil and filter with me to SRR encase i end up with fuel contaminated oil??
Thanks for the help.
