Yeah I had to remove oil filter an all.
Pain in the ar$e, the whole job took me 8 friggin hours, I had some rad flush aswell so had to drain it fill it bleed it twice and aswell as that, I took the dipstick off the thermostat housing to manage to get it out and then trying to bolt dipstick back on I took the dipstick out of it's housing to make life easier.
.oh no!! Pulled all of it out of the block, then the o-ring at end of dipstick housing fell apart when I wiped it clean, then it wouldn't fit back in properly, so of course it didn't line up right to get bolt back in, so just cable tied the sodding thing for now.
It's shaped like a dogs leg so u can't get any pressure on it to push it in, so only lord knows how I'm gunna get it back in once I've got a new o-ring, possibly off with the oil filter again?!
Any ideas anyone? Aren't these mr2's a pig to work on eh?!
Oh and as for bleeding off Dave, go onto mr2oc.co.uk on the know your two section, there's a proper procedure on there mate, you can't just burp it.
Anyways any advice for me on my probs would be much appreciated, think I'm goin mad!!
Regards, Dave.
