first tecchie post, nice to meet you all.
got a mk2 tubby with blue flame exhaust
The standard boost has probably crept up a bit with these mods.
done a lot of reading about manual boost controllers and t-vis.
understand that the mechanism remains in the inlet manifold and when you fit the manual boost controller, this in effect is redundant and you block off the small pipe to the tvis from the wastegate.
my question is
