[Mk2] [NA] Name that tune (TAPPING NOISE)
flackie666
Post by flackie666 »
can any of you amasing people tell me whats causing this noise???
Please!!!!!!!!!!!!!
Not So Fast But Just As Furious =]
Dale_V
Re: [Mk2] [NA] Name that tune (TAPPING NOISE)
Post by Dale_V »
sounds like the big end bearings have had it to me
going4the1
Post by going4the1 »
Sounds as though it could be exhaust related. I suspect it is the 'pin' which holds the front pipe at the rear subframe:
See:
http://www.jap-spec-performance.co.uk/m ... na/fp.html
I think it has sheared off but the rubber mount is holding it against the exhaust giving the rattle.
You can see this from above - rear bulkhead - offside
flackie666
going4the1 wrote:Sounds as though it could be exhaust related. I suspect it is the 'pin' which holds the front pipe at the rear subframe:
See:
hahah oh god do i wish your right but it sounds like its coming fromt he top of the engine
BUT ive just rememberd the exhaust is blowing and i dont no why yet
Steve Horrocks
Post by Steve Horrocks »
Dale_V wrote:sounds like the big end bearings have had it to me
I'm with Dale on this one sadly.
black gts
Post by black gts »
iv refitted charcoal canister vavle back on my 2 and what a noise , touch the throttle and it stops but not for long
easty-5
Post by easty-5 »
Doesn't sound like big ends to me. When they go they tend to go with the the RPM's. I.E. faster the RPM's, faster the knocking.
Post by Martin F »
easty-5 wrote:Doesn't sound like big ends to me. When they go they tend to go with the the RPM's. I.E. faster the RPM's, faster the knocking.
I agree, could be a camshaft/shim problem :-k
p.s. you might want to set you photobucket account to private :wink:
flackie666
i just changed the oil as i was going to do it anyway the oil i got out was very very metalic so im sure somethings not right. and the noise seems to be coming from the top of the engine
Steve Horrocks
Quick check for big ends, put car in first, without using any throttle, let engine idle, with hand brake on, and lift clutch up slowly so engine is nearly stalling. If big ends are gone/going it should so up with that nasty death rattle noise that sounds like the video.
flackie666
can thay just be changed or will this have caused damage to the engine? and how big a job is it to change them?
