Please!!!!!!!!!!!!!
![Image](http://i231.photobucket.com/albums/ee243/flackie666/th_Taptapbang.jpg)
![Image](http://i231.photobucket.com/albums/ee243/flackie666/th_InCarTap.jpg)
going4the1 wrote:Sounds as though it could be exhaust related.I suspect it is the
'pin' which holds the front pipe at the rear subframe:
See:
http://www.jap-spec-performance.co.uk/m ... na/fp.html
I think it has sheared off but the rubber mount is holding it against the exhaust giving the rattle.
You can see this from above- rear bulkhead
- offside
Dale_V wrote:sounds like the big end bearings have had it to me
easty-5 wrote:Doesn't sound like big ends to me.When they go they tend to go with the the RPM's.
I.E.
faster the RPM's, faster the knocking.
