just wanna know which one is the better one before i part with cash either way
hearsay doesnt count im afraid
dai21t wrote:
but if you're on about chargecooler rads then the 205 one doesn't fit the mr2 whereas the fiat one does.
Leaki Tbar and I fitted one to his Rev 4(without air con) and it was a simple straight forward job, was perfect fit and hose ends were easily workable as well, also a very efficient rad.
Ruishy1 wrote:im not asking about efficient enough, id like to know the more efficient one![]()
that sounds nasty mate but its not meant like that![]()
Ruishy1 wrote:the bigger rad, the lower the temps, the higher the power, every little helps
