Can anyone recommend me an aftermarket oil catch can?
Thanks,
Nik
Steve-O 2007 wrote:I fitted a Cusco catch can to mine-
http://url194.imageshack.us/url194/3351 ... medium.jpg
http://url9.imageshack.us/url9/4640/050 ... medium.jpg
dai21t wrote:Why do you need a baffled can? Surely your engine shouldn't be chucking that much out.
Dangerous wrote:U can but my greddy one if you like as i dont really need it..
It has a sight glass and is in good nick..i'll even throw in the aeroquip hoseing in aswell!!
I,m just gonna put a filter on the oem catch can instead of having 2 of them..
(catch cans)
the cusco is the best, even though its more expensive if you notice the clear hosing it has metal baffles in it.These baffles separate the oil from the air and collects the oil in the catch can.
This is what a catch can essentially does, separates the oil from air.
the other two are different.They have cheap crappy hoses which do not contain baffles.
There is however a way to get over this problem.
People
(including myself) open the top of the catch can and put stainless steel wire in to act as the baffling.
HINT**** The cheaper ones are good, but make sure u get one that has a removeable top, or you wont be able to stuff it with steel wool.
