just about to fit my ebc and the instructions mention a single port or dual port actuator. which one do i have? its a ct20b.
and for all the pic whores out there, can i see pics of where youve put your ebc?
cheers.
Its a dual port, remove and block the second one that goes to the factory boost controller at both ends (I used a 10mm bolt and a hose clamp) and run the second port to your ebc. You can use either port, they are both the same.
Dont have a pic but I mounted mine using an existing bolt hole on the firewall on the air intake side. Planning on moving it though as a fair bit of noise from the soleniod it transmitted in the cabin.[/list]
