dual port actuator?? and where have you fitted your ebc?
redmr89
Post by redmr89 »
just about to fit my ebc and the instructions mention a single port or dual port actuator. which one do i have? its a ct20b.
and for all the pic whores out there, can i see pics of where youve put your ebc?
cheers. :thumleft:
MRGEN3TURBO
Re: dual port actuator?? and where have you fitted your ebc?
Post by MRGEN3TURBO »
Its a dual port, remove and block the second one that goes to the factory boost controller at both ends (I used a 10mm bolt and a hose clamp) and run the second port to your ebc. You can use either port, they are both the same.
Dont have a pic but I mounted mine using an existing bolt hole on the firewall on the air intake side. Planning on moving it though as a fair bit of noise from the soleniod it transmitted in the cabin.[/list]
MR2 sticks like glue
redmr89
Post by redmr89 »
cheers . i thought it was. just needed confirmation.
anyone got any pics of theres? particularly the control unit in the cabin.
MRGEN3TURBO
Heres where I put mine, in the centre storage console out of the way of prying eyes and the fuzz
redmr89
Post by redmr89 »
i was thinking of putting mine there but its hard to access it while driving.. ie selecting high and low boost...
Quigonjay
Post by Quigonjay »
you can get a steering wheel mounted switch for switching between high and low
redmr89
Post by redmr89 »
ive never seen one before.. any ideas on cost?
nailmonkey
Post by nailmonkey »
Just leave it on high and use your right foot to control the boost!
Nik
Tiny turbo + standard exhaust + aircon = 346bhp/300ft/lbs @ the hubs!
redmr89
Post by redmr89 »
lol. i knew someone would say that..
