right,
ive changed the starter motor now and i still have problems getting the car to start.
the battery is fine as ive measured the voltage and stuff etc.
this morning i turned the key.
.nothing.
.just a clicking noise i can assume is the starter motor.
then after leaving the key turned it began to slowly come to life.
feels like when your alternator is not charging the battery and you get the slow burst into life.
.but not.
are they any relays or fuses to check? ive just cleaned my earthing points up, all except the starter motor, which i should have done at the weekend but forgot.
any ideas?
