[Mk2] [Turbo] Best Turbos for quick spool up?
tarmac terrorist
Re: [Mk2] [Turbo] Best Turbos for quick spool up?
Post by tarmac terrorist »
i run a gt3076 63 trim full boost by about 3700
without a full map (had to abort run)we reached 405 whp
Race Idiot
Post by Race Idiot »
Anyone here with a GT3071?
Post by Martin F »
Race Idiot wrote:Anyone here with a GT3071?
was earl not using a gt3071 when his car was running 451 bhp :-k
bolton
Post by bolton »
ive got a 3071r waiting to go on cant wait!!!
mattymr2
Post by mattymr2 »
im confused by all these turbos! lol
when does the standard c20 hit full boost?
steve
Post by steve »
i was getting full boost (1.2bar) by 2.9-3k rpm on my old 2 with a ct20b :thumleft:
i'm probably going for a 3071r .63 once my engine is run in, but that might change once Nick takes me for a spin in his 2 with the 3076r (graph above^)
Race Idiot
Which is the faster spooling turbo out of the 3076 and the 3071, although I guess it depnds on the trim
RobCrezz
Post by RobCrezz »
Race Idiot wrote:Which is the faster spooling turbo out of the 3076 and the 3071, although I guess it depnds on the trim
3071 i think
tarmac terrorist
3071 is slightly quicker but can not push as much power as the 3076
mattymr2
Post by mattymr2 »
im struggling to find info on the 3071 and 3076.
whats the max power these acheive? and revs they can reach full boost?
really im after a turbo that is smooth in power delivery that kicks you back but doesnt jump out at you all of a sudden like the bigger, laggier turbos.
most of all i want it to be driveable and enjoyable on a track, not just on the drag strip.
tarmac terrorist
i would go for the 3076 mate , love the way it works starts pulling well from 3000 then at about 3700 is when all hell breaks loose,the last time me bro went out in the car it was not mapped at the time when the power came in he said it felt like some had put there hand on his head & yanked it back lol, as for power i think the 3076 63 trim is good for 515 bhp approx
this is where mine came from
http://www.koracing.net/viewproduct.php ... roduct=187
kameleon
Post by kameleon »
blitz k1 380v if you can find one. std bolt on but is pefect for what your after.
even looks stock!
craig_mr2_mk1
Post by craig_mr2_mk1 »
This isnt what your talking about is it?? ebay item no. 110404347311
Craig.
mattymr2
Post by mattymr2 »
http://2bartuning.com/dynographs/
found this. might be helpful for people with similar queries as me.
RumbleStrips
Post by RumbleStrips »
Where is a good place to buy some of the turbo kits mentioned here?
jimGTS
Post by jimGTS »
When people are talking about full boost by X amount of revs. What gear are your refering to???? All gears will get your slightly different results for full boost.
I asume your talking about 3/4 gear. Ie your dyno gear to see graphs of the spool.
ashley
Post by ashley »
At the risk of looking really dumb, why would gearing have an effect on the boost threshold? Surely boost threshold is determined soley by the gas flow through the engine at certain rpm and the characteristics of the turbo you are running?
Marf
Post by Marf »
ashman wrote:At the risk of looking really dumb, why would gearing have an effect on the boost threshold? Surely boost threshold is determined soley by the gas flow through the engine at certain rpm and the characteristics of the turbo you are running?
Load.
Higher gears give higher load which means more gasflow and faster spool.
jimGTS
Post by jimGTS »
Load.
exactly...
for example i can hit full boost in 5th at 3.9-4k rpm, but in second, may not be til 4.5k. depends if im flying through the gears or not as well.
ashley
Post by ashley »
Cool- cheers for explaining :thumleft:
