Any ideas for this? my car is a rev1 turbo.
I have checked the TPS and set that up correctly!
Also as you know theres a screw on the TB which alows you to adjust the idle speed.
The AFM is also correctly adjusted.
Please any help?
One more thing i did take the throttle body off partially to check my hoses and to give the butterfly a quick clean.
Thanks in advance
