Hey all as above, mr idle is about 1200rpm when warm and 1500 when cold.
Any ideas for this? my car is a rev1 turbo.
I have checked the TPS and set that up correctly!
Also as you know theres a screw on the TB which alows you to adjust the idle speed... Thats on its minimum setting!
The AFM is also correctly adjusted.
Please any help?
One more thing i did take the throttle body off partially to check my hoses and to give the butterfly a quick clean.... Could this of caused anything?
Thanks in advance Scott
Turbo idle 1200rpm when warm?...
Re: Turbo idle 1200rpm when warm?...
Anyone? Its driving me insane!
idle control valve clean?
any leaks on the intake?
cold start injector switch not turning off the signal to the injector?
