Whoops 3 holes not 4 doh
If I remember correctly the turbo ones are the same size, yes they are as I used both of them as rears as originally I received
pfr76-308 and pfr76-309.
"Just a case of removing the whole mount
(do I have to support or lift the engine in any way????)"
Just unbolt the mounts and remove them the engine wont move
(I have replaced both mounts in under 15 minutes using just a trolley jack) you need a u shaped spanner.
"Bash or burn out the old mount?? I heard oem mounts have a metal sleave on the outside of the oem bush
(inside the mount)? Correct? This need to be removed to? Or will work with the poly bush?"
I cut most of it out then tipped white spirit
(all I had to hand) and burned the rest out I left the metal ring in
(other people say to remove it powerflex said either or as I had made it up with it in and wasnt sure if I should take it apart and remove the ring or not so its still in there) it was hard work to get the inserts in, but I managed it, then put the sleeve in I took a bit longer as I painted the mounts before fitting the inserts.
"This is not a 20min going by the ad then"
No I would allow 2 hours or a bit longer if you intend to paint the mounts it would be quicker on the na mounts as the rubber always falls out on the 73mm front in my experience.
Good luck with it.
