coil overs have turned up they look that fitted the two fronts tonight at work doing the rears tomorrow,only small thing is the support for A.B.S wiring is not on these coil overs other than that they are great, next i need to get some new drop link rose joints as are knocking there boobs off,
also want to get some rose joint bottom track arms but got to save for a bit after that i think thats about as far as i can go with suspension unless anyone can think of anything else,ideas welcome:
current spec:
1) BC
(APEX) coil overs with pillar balls front
& rear
2) white line rear anti roll bar
(set full hard)
3) white line front anti roll bar
(set medium)
4)rear cusco strut brace
5)front cusco strut brace
6)front full under body brace
7)front under track arm brace
8)full poly bush set
9)front inner wing braces
camber set: front
-1.5
rear- 1.0
(may change these settings)
if i had not had such a clean car i would of had the shell seam welded
