It has an aftermarket system with decat, open cone filter and FCD.
What boost can I
Thanks guys.
Cheers!
Oh right that's a little dissapointing
Mr_Two wrote:So I'm guessing around 250bhp~ with those mods at 1 bar?
So if I put a CT20b on will it be slightly better?
Steve-O 2007 wrote:You dont want to go anymore than 1 bar anyway on the Rev 2 headgasket unless you plan on getting a new headgasket fitted?.
rev 3 headgaskets drops straight on and are stainless if i am correct??
The ct26 is really restrictive and upgrading to the ct20 makes a massive difference
Mr_Two wrote:First step I think is CT20B then 1 bar and see what happens!
thebody wrote:I diagree JJ the ct26 really tails off when running 0.9 bar by the time youve reached redline youve prob tailed off to 0.7 bar maybe less where as the ct20 keeps going![]()
