Spec:
1987 E reg JDM model
5-speed manual gearbox
White over Silver
approx 79,000 miles
Just passed MOT
12 months road tax
T-bar roof with roof sunshades and T-bar panel bags
Black interior with black/grey check cloth seats
OZ Superleggera 15inch alloys in gunmetal grey
Aircon system is present but doesn't work
The car is pretty much in standard form.
I fitted some clear side repeaters to the car but the originals will be provided if someone wants to put them back on.
The car won't come with a stereo as the stereo I have in it was a present so I want to keep it.
Work done on the car since I've owned it:
New clutch master cylinder fitted
Brake fluid changed and bled
Front brake pads replaced
One rear caliper replaced with a reconditioned unit
Koni adjustable suspension fitted
Water pump replaced
Cambelt replaced
Supercharger drivebelt replaced
Oil, coolant, air filter, spark plugs have all been replaced during my ownership
I've got receipts for all work carried out while I've owned it.
I've got previous MOT certificates and tax discs.
I'll try to add more details and info later on when I'm at home as I'm currently at work and have a meeting to go to now!
Price is
Thanks,
Andrew
EDIT 12 June 2008: More pictures added below
There are a couple of bits of rust but the bodywork is generally very tidy IMHO:
The first was at the base of the drivers' side B-pillar.
The second place is on the passenger side rear wheel arch.
The third place is just above the drivers' side rear light cluster where the boot rubber seal goes round.
The paintwork comes up well with a wash and polish.
The Toyota decal on the front bumper is quite tatty.
Work carried out to pass the MOT this year:
Two new numberplates
Both front headlight aims adjusted
Exhaust manifold gasket replaced as it was blowing
Repair to driver's side B-pillar base
I will take some pictures of the interior of the car and any other close ups that seem relevant when I can.
