ok, I finally finished this.
Here's how it went:
(Note that I had acces to a proper garage and bridge so working underneath the car was very easy)
First night:
(18u30-22u30)
- Spend an hour or so letting the car cool down, remove the plastic covers and drain all the coolant.
Removed all hoses, water reservoir and timing belt covers.
Found out you have to raise the engine a bit to remove the water pump pulley.
Got the water pump itself out
(not the part between the pump and the engine/hose)
Gasket wouldnt come off, so spend ages sanding it down.
Second Night:
(18u00-22u30)
- Spend some more time sanding down the gasket.
Installed a new water pump with gasket
Bolted everything back on.
Raised engine to fit waterpump pulley and used a plier to bend the lower timing belt cover so it would fit around the needle sticking out
(you"ll see what I mean when you get to it)
Filled it with coolant
BIGGER LEAK THAN BEFORE, banged my head against the wall
Third Night:
(17u00-22u30)
- Went to mr T and got a new gasket and 2 O-rings
(11 incl taxes)
Drained coolant, removed everything
(again!)
Removed water pump and the metal piece between the engine block and water pum.
Removed old gasket properly this time.
New O-ring in engine block and waterpump
(O-rings are slightly to large, might take some fiddling to make them fit)
Fitted everything back together.
Filled with coolant, no leaks
Then on the way home the water hose from the filler cap to the engine block broke or got loose and it started leaking again.
No 200km drive for tonight
Conclusion:
If you are doing this for the first time and haver never done anything except basic maintenance it will take A LOT of time, save an entire day, a weekend if possible.
But I'm sure if a white collar college boy like me can do it, everyone can do it.
Replace the O-rings.
Sure mr T rips you off at 2,5 each but you absolutely don't want to redo everything because one fo them started to leak.
Test for leaks with water, I wasted 5l of coolant.
