[Mk2] [Turbo] will these size wheels be ok on my car
sl8ter
Post by sl8ter »
8.5" x18" ET 35 x 114 ? with 225/40/18 tyers all round (my car is a 92 k reg tuby)
raptor95GTS
Re: [Mk2] [Turbo] will these size wheels be ok on my car
Post by raptor95GTS »
fronts will rub the suspension strut as the wheel is too wide. Same sized tyres all round is a bad idea you should have at least 20mm wider on the rear
gts 400
17's only
Post by gts 400 »
18's really big for mr2 better with 17's will handle loads better!
i have 245/35/17 rear 8.5j and 7.5j front 215/40/17 fine on super street sus rota light weight wheels heavy wheels no good at all!
sl8ter
Post by sl8ter »
nice one thanks for that
gts 400
no worries
Post by gts 400 »
i had a nightmare with wheels and tires mate !!!! 3 or 4 sets befroe i settled with this combo!
had 255/40 tires on split rims cost 2000 they were xxxx came bent and were so heavy ! steering was awful!! rota were 870 with the tires! you will need the 35 off set you can do 40 but i had to buy longer wheel studs! they were about 35 i think ?
good luck with it :thumleft:
BiGWiLlYsTyLe
Post by BiGWiLlYsTyLe »
Yeah i would just go for 17s as the handling is not very good with 18s due to the centre of gravity being higher so it will roll on corners.....mind they do look good but i think the downsides outweigh upsides!
I was gonna get 18s but pulled out at the last min and got 17" black asia tec Yakuzas!
sl8ter
Post by sl8ter »
nice one :thumleft:
