Over the last 3 weeks I've been refurbishing my brakes, changing pads
& rear discs.
This started as one rear brake binding, then once I saw the state of it I investigated the other rear brake, discovered it was on the way out as well, and decided while I was there I might as well do the lot.
My car is marooned at work with no brakes atm, so I have only been able to do things to it during my lunchbreak or in the hour of daylight after work finishes! This has involved a lot of waiting around for mail order bits to arrive due to a lack of transport.
As you can imagine, once I'd got it all back together I was rather eager to bleed the brakes and get behind the wheel again!
I knew the car had DOT4 fluid in it, so I nicked a bottle of Lucas DOT4 off my dad and went at it.
This was my first bleeding procedure:
Starting with passenger side rear wheel, then drivers rear, then passenger front, then drivers front.
Mate in the driver's seat.
Me at the relevant wheel.
Loosen bleed valve, push brake pedal.
Tighten bleed valve, release brake pedal.
Repeat until plenty of fluid comes out of bleed valve.
Check reservoir every 10 pumps or so to make sure we don't let any air in that way.
Once brake fluid is flowing, tighten bleed valve, pump pedal 6-10 times until stiff again, and then with pedal depressed, release
& tighten valve again.
Repeat with other 3 wheels.
Once I'd done the above, the pedal was very spongey and the brakes didn't function.
So, I went round again, making sure I hadn't missed anything.
All seemed fine.
In the course of these 2 bleeding sessions it ate the whole 500ml of Lucas DOT4 fluid, so I bought a litre of Toyota DOT5.1 for a fiver off eBay.
I hadn't intended to buy Toyota branded as I figure brake fluid is all much the same as long as the DOT value is right, but it happened to be cheap.
Mildly peeved, I hitched a lift to Halfords to get a one man bleeding kit.
I checked and the eezibleed kits that use pressure from the spare tyre don't work on my car as it has a pop on cap on the brake reservoir rather than a screw on one, so I bought one of the kits which has a pipe with a one way valve in it.
Back I go and this lunchtime started bleeding again.
In the same order as the first time round, attached pipe to bleed valve, loosened, pumped until no bubbles were seen in the pipe
(which is about 1ft long) as per instructions.
Did the same thing with pumping the pedal a few times and then releasing
/ tightening the valve.
All 4 wheels later, pedal is even softer than before
(??????) unless you pump it 4 of 5 times at which point it stiffens up again for
~10 seconds.
At this stage more than mildly peeved as I was meant to be going to the cinema tonight, and having run out of lunchbreak, I decided to give it another going over after work.
So I ran through the whole procedure again, which has now used the remainder of my DOT5.1 fluid.
Surprise surprise, the braking system is still just as useless and still only stiffens up when you pump it!! I AM NOW VERY ANGRY!
I have now bled my brakes following 2 different procedures
FOUR
times!! Where in the name of flange am I going wrong?! Have I just got a brake system that's posessed by the devil?
