Morning Lauren, i would definately go for the hole in the bulkhead, it really is a nightmare of a job to take the dash out, simply appauling
& it would really end up testing your love for the car in the end
, its got to be better than ending up with this mess
if you use the Dremmell i find the reinforced dics with the fibre running through them a really good cutting disc and last heaps longer than the others, only one other thing to add to this, if you can change the heat exchanger
( think this is what its called, the thing with 3 coils on it
) it would be worth it as mine was very thin and looked like it had nearly burnt through, this would probably save you a lot of grief later, if you need one i can send you one foc if you get stuck, GOOD LUCK, you will need it, i will say a prayer to the Toyota gods for you.
they owe me one
, Jinxy
