[Mk2] [Turbo] Tein Super streets - now fitted with Feedback
spannerman
Post by spannerman »
New suspension is required on Rev3 Tubby, current stock setup is really crashy, think the springs have sagged + they're just worn out. Also possible they are almost running on the bump stops so when hitting a bump its not good :(
Originally wanted Yellow Billies and Eibach springs but having looked into the Tein Super Streets I'm leaning towards these.
Apparently spring rates are:-
Front 3kg/mm
Rear 5kg/mm
I hope I'm correct in thinking this will provide a nice compliant ride. I live in West Yorkshire and the roads are an absolute mess.
I've not known any other suspension setup on the 2 other than Stock so if these are a better ride and no doubt make the car feel more positive then I'll be happy.
Interested to hear any views of owners running Tein Super Streets, please?
How is turn in after fitting?
Traction under braking etc?
Cornering lean?
Kind regards
Spannerman :D
MR!! wren
Re: [Mk2] [Turbo] Tein Super streets - now fitted with Feedback
Post by MR!! wren »
well i've just fitted mine, but unfortunately still have a lot of other xxxx to fit too, so wont be running for a week or two. interested to hear what others think of theirs too, though!
Harry
Post by Harry »
Spannerman three words > BUY THEM NOW! :wink:
Race Idiot
Post by Race Idiot »
Bah, get a set of Silk Road RMA8s instead. Mainly because I want to know what they are like for use in the uk.
guss76
Post by guss76 »
Added the same SS superstreet and to my suprise the ride was really good, have not really hustled her around corners yet however it feals really good so far
Kitch
Post by Kitch »
Harry wrote:Spannerman three words > BUY THEM NOW! :wink:
i listened to hazza and was a awsome decision!!
do it now
Harry
Post by Harry »
i listened to hazza and was a awsome decision!! do it now
:lol: :clap: :wink: The Best!
DavidM
Post by DavidM »
Where from and how much?
EX Caribbean Blue 10th Anniversary 1996 T-bar
EX Black 1995 mk2 GT Turbo
NOW Audi TT V6 3.2 DSG 2004 Coupe
Harry
Post by Harry »
The Tein 'Super Street' adjustable coilover was designed to provide driving comfort and sports performance. This kit offers offers fully adjustable ride height as well as 16 levels of adjustable damping force. Complete with Tein front pillow ball top mounts and rear reinforced rubber topmounts the Tein 'Super Street' set-up is considered one of the best kits on offer for the MR2, you won't be disapointed.
Front height adjustment range, -20mm to -45mm
Rear height adjustment range, -15mm to -45mm
Now with FREE Delivery!
Manufacturer: Tein
Category: Suspension & Chassis
Price: £757.44 (£889.99 including VAT at 17.5%)
Availability: Usually available 2-3 days
Postage: Free Delivery (£0.00)
Available for: MR2 Mk1 normally aspirated (early) MR2 Mk2 Turbo (revision 1)
MR2 Mk1 normally aspirated (late) MR2 Mk2 Turbo (revision 2)
MR2 Mk1 Supercharger MR2 Mk2 Turbo (revision 3)
MR2 Mk2 normally aspirated (revision 1) MR2 Mk2 Turbo (revision 4)
MR2 Mk2 normally aspirated (revision 2) MR2 Mk2 Turbo (revision 5)
MR2 Mk2 normally aspirated (revision 3) MR2 Roadster / MR-S (early)
MR2 Mk2 normally aspirated (revision 4) MR2 Roadster / MR-S (late)
MR2 Mk2 normally aspirated (revision 5)
http://www.roguemotorsport.com/forms/Pr ... spx?ID=368 :+: Rogue Motorsport; Supply and Fit.
Caribbean_Blue
Post by Caribbean_Blue »
Super Streets are one of the best mods I did to my car hands down.
Get from Rogue Motorsport. They deal with UK roads pretty well - you need to make a concious effort to avoid drains & 'craters' in the road!
If you have the money - do it.
spannerman
Thanks for your info Guys, once fitted I'll post up my feedback.
Gonna swap anti roll bar bushes whilst I'm at it also.
Spannerman
RST
Post by RST »
If you can splash out on poly sus. bushes go for it as well -I think Rogue's prices were very competetive. Can't remember how much they were.
spannerman
OK, Tein Super Streets fitted and Polly Anti-roll bar bushes and I'm really happy with them.
The Tubby now turns in quicker with less input needed from the steering and it all feels more planted and much more predicable.
I havn't had much of a play with the settings, currently running on 12clicks back from fully hard (the start point the manual recommends).
As for ride comfort its almost like they have a mind of their own. Hit the little bumps at slow speed and it absorbs them well, yet when you start pushing the speed its nice and stiff with minimum body roll.
All in all, a very compliant set up.
Comfortable with the bumps, pot holes etc then firm enough when carrying more speed into the corners. They have certainly increased confidence in the car, feels much more planted.
Highly recommended as many of your have said previously.
Thanks very much guys :)
Spannerman :)
Harry
Post by Harry »
8) 8) Enjoy,mate! :thumleft: :mrgreen:
MR2D2
Post by MR2D2 »
reading this post i think uve solved my question of what suspension to get :D ... only question is whether to get the tein top mounts or not? ...
what do they improve and is it worth it for the money?
spannerman
I went for the poverty setup and used the standard top mounts.
As for improvement, the ride is no longer bouncy just firm and compliant.
Highly recommended.
Spannerman
Harry
Post by Harry »
MR2D2 wrote:reading this post i think uve solved my question of what suspension to get :D ... only question is whether to get the tein top mounts or not? ...
Reference the metal top mounts: strictly speaking they are more of a race circuit type unit the metal gives greater feedback of the road and wheels and are more compliant making the ride a touch harder. Having said that as the name suggests,Tein Super Street,are designed for the street and have a lower spring rate as described In the feedback from Spannerman.
If one Is using the MR 2 as an every day car and perhaps the odd sports day then I think the stock top mounts will be fine and a bit softer on the rougher roads.If going this way I would consider buying new OEM rubber stock units say from JeffD, here who might supply them at a lower price than Toyota? Other good choice Is TRD, rubber top mounts they are slightly harder up rated over the stock OEM rubber mounts.HTH. :)
I went for the poverty setup and used the standard top mounts. As for improvement, the ride is no longer bouncy just firm and compliant.Highly recommended. Spannerman
You have built a solid base foundation, and wise to do so! :wink: One can update other parts later as funds allow! :D
MR2D2
Post by MR2D2 »
wonderful ... ive got some really good top mounts that I had for the last mr2 so il just use those for the moment ... cheers for the info :thumleft:
darrenmr2
Post by darrenmr2 »
Ive just bought some TEIN superstreets today from Patrick @ Rogue. Getting them fitted next thursday, cant wait :D Didint get the TEIN top mounts though, although i purchased some TRD uprated top mounts from Fensport :thumleft:
Kubus
Post by Kubus »
U lot are making me crazy :) i really dont know now if i Should get uprated clutch and LSD box or buy a tein superstreet standard kit - without the top mounts ....
what U think ?? lol
