[Mk2] [Turbo] advice buying a rev 4 turbo..
cornyenty
Post by cornyenty »
right... seen this rev 4 turbo i like... the car is in superb condition with some tasteful mods 2, but always a but.. the only problem with it it needs a gear linkage be cos the 3rd gear is sometimes hard 2 get in.. he has just bought some new 1s and has no time 2 fit before sunday... is this true and what advice can u give me.. is the gear box fooked ? or does this sound right and expensive 2 fit? :whistle:
dawolf
Re: [Mk2] [Turbo] advice buying a rev 4 turbo..
Post by dawolf »
Hmm, not sure it would be caused by the linkages. Seems like he's trying to make it look like a cheap fix. It's not a great sign when gears don't go in very easily.
cornyenty
Post by cornyenty »
so , keep well away or could it be sorted... how much 2 sort out the gear problem..
ddmotorsport
Post by ddmotorsport »
have you driven the car ? can you describe how it is hard to get into ? any noises (grind - crunch) ???
cornyenty
Post by cornyenty »
nope not driven the car yet... but he has told me this... the 3rd gear sometimes is hard 2 get in,with a crunch/ grind. ive had a think about it and im keeping away.. sounds like a expensive road 2 go down... :eye:
dawolf
Post by dawolf »
It could well be worn syncro's which means a rebuild or replacement gearbox. You can pick up low mileage ones off e-bay for around £250 but there's always a risk. Rebuild would be about £450ish.
chrisbr68
Post by chrisbr68 »
Fensport can do you a low miler with LSD for £350
