[Mk2] [NA] turbo plug wires abd distributor on a NA
dinkyboy
Post by dinkyboy »
Problom:
the cas in slower speeds is jerky and gives a feeeling that the engine is missing. this does not happen a high speeds. Also at slow speeds or at traffic signal stops i can feel the car jerk and wobble and miss.
Advise:
have been advised to change the plug wires as one of the wires was found to be shorted.
Issue:
Parts are not easily available in India. my parts supplier has a plug wire set for a Turbo model. He does not have one for a NA model. he is advising that i also change the distributor cap as well (he has another one for a turbo model) and replace both the distributor (i think that is where the other end of the wires fit in, probably called the dizzy cap but i am not so sure) and the wires.
Solution????
is is advisable to put a turbo plug wire and dizzy set on an NA? will this work or will it create some other problom?
pls advise
