just removed my k&n filter from my 93n/a and replaced it with a bmc cda filter.
liked the k&n but hated the fact water could be absorbed into the foam when in a heavy downpour as its located beneath the bonnet vents.
now to fitting the bmc cda
couldn't wait to fit until i opened the box and saw the size of the thing and released there was no way it would fit straight onto the throttle body.
luckily i work at a motorcycle company so i had two small 45 degree stainless pipes welded to angle the box into an open space.
i used some 63mm samco hoses to join everything together and hung the filter with the supplied bracket and then placed the intake hose to the side vent to draw in cold air.
All this took about 1 hour.
The sound is different to the k&n and it also feels like there is more
Overall i'm really happy with the product and performance and would recommend to others.
Any opinions from people with this kit would be interesting as i couldn't find many people with these fitted.
PS
regards mark
