Spotted this http://www.rossmachineracing.com/3sbucket.html
Anyone tried it?
Shimless conversion using MRS spider buckets
Re: Shimless conversion using MRS spider buckets
you need to speak to gts chris,hes done it if i remember right.
Paul Woods wrote:you need to speak to gts chris,hes done it if i remember right.
yup, just follow the instructions on that weblink.
Chris, I take it these are a direct replacement from REV2 shims and buckets, no mod required?
Was gunna order some as soon as I measure the ones I've got.
Dont want a shim popping out at 8000rpm.
Get my Dad to use his staff discount.
Terry wrote:Chris, I take it these are a direct replacement from REV2 shims and buckets, no mod required?
Was gunna order some as soon as I measure the ones I've got.![]()
Get my Dad to use his staff discount..
drop straight in, just make sure u do you measuring carefully
I'm presuming for this mod you would
Knowing the lift of your new cams versus old cams, minus this difference from the original bucket thickness, and order the new bucket in the correct thickness avoiding putting thinner shims in?
Sorry a bit of a novice on engine rebuilds
Jimbob wrote:I'm presuming for this mod you would
na, bit more to it than that.
stick you new HKS or whatever cam in and check clearances, then work out what new solid lifter you need by looking at the clearance
Will the higher lift cams mean less clearance though as they have longer lobes? Am I totally stoopid?
So would you measure each one to check for uneven wear?
Is it worth getting a new set of valves at this point.
I understand rev3's and st205 gt4's have slightly larger valves and those on the st205 are sodium filled
