Negativvv wrote:The questions i have is how much difference is there between an sc and an n/a? A friend thinks i shouldnt waste my time as the bhp gain is only modest but the torque gain is pretty big! While i dont find the n/a slow as such, it isnt exactly fast either!
Oh and how different does the sc sound? Its important that i can hear the sc whine a bit.
Thanks!
Well, if its an AE101 conversion with the I/C removed and WI fitted.
.there is a LOT of difference.
Compared with my old N/A.
.no contest!
I have the standard pulley.
.10psi
(measured both electronically and mechanically).
.stock ABV, and it suits me fine.
I have bought the oversize pulley, but cannot be ar$ed to fit it.
TBH, the SC12 is a crap supercharger: almost any modern Eaton p1$$e$ all over it.
.if you fit the oversize kit, it merely brings the unusable inefficiency band down the rev range.
.unless you start spending on uprated intercooling, etc.
But whatever you try to cool the charge down, its p1$$ing in the wind, at the end of the day.
Solution.
Fit a more efficient S/C.
(M62
/ M90
/ or a twin-screw: Whipple, IHI, Sprintex, etc)
Then you'll be in the 200hp bracket, but with shedloads of torque low down.
