[Mk2] [NA] please please help stereo grief
fearless
Post by fearless »
hi tried wiring up my birthday present today im normally quite good at doing stereo's untill fitting into a japanese car ](*,).
looked at all the diagrams on here printed off and went outside to attempt
it put meter on wires and found a perminent live which was a white wire strange i thought nomally there red, still connected it to radio and run my own earth to body radio powered up all ok now to find speaker wires found 8 wires in cable on there own colours are different to what i printed off i have no sub behind seat cant get nothing out of speakers thay worked with toyota stereo wires i have
yellow
black
red
green
white
blue
brown one silver dot
brown 2 silver dots
all these run through the same loom
second set of wires
black wire red line through it
white wire green line through it
pink wire blue line through it
third set of wires in own loom
green wire
red wire
white wire
black wire looped back into loom
please if someone can advise it would be apreciated really dont want to have expert to fit it and get get charged £30 always done my own radios in past just these japanese cars ](*,)
jon0406
Re: [Mk2] [NA] please please help stereo grief
Post by jon0406 »
Mine was fairly straight forward, you just need to know if you have a passive or active system, purchase the correct ISO adapter, connect two of the sets of wires into it (the ones that fit, you will have a 3rd but this might not be the set you have called 3rd in your post) and the job should be a good un! :thumleft:
I did have one spare set of wires and was told these weren't needed (something about an extra aerial in the front screen)
Thats how it was when I did mine, I had a double din unit and was wiring a new unit into a Rev 3 Turbo.
ISO adapter was bought here:
http://www.caraudiodirect.co.uk/fitting ... 2_317.html
fearless
Post by fearless »
my wires were all chopped up so bought iso connector with bear ends to make a neater job someone had really hacked them big time so started again ](*,)
jon0406
Post by jon0406 »
Oh, that doesn't sound good. :shock:
Sorry I can't help then, that £30 doesn't seem like money badly spent to me, I know what I'd be doing in your situation!
StuartLaws
Post by StuartLaws »
If someone can indicate which is which wire that would be handy for me, I had a new stereo fitted to mine and since then the battery runs down if I leave her unused for more than 4 days....
Easy answer, go back and get them to check the work, unfortunately the Jap car specialist has now left and hasn't been replaced....Money refunded though so not a huge loss.
I'm happy to sort it out myself, but I'm not clear which wire is which on the 2 cable groups that don't seem to be connected to anything at the moment.
Stereo works fine though, so something must be plugged in the right place, I suspect there is an open circuit or something...
If nobody knows which wire is which by colour coding, does anyone know of a good audio specialist in the Twickenham/Richmond/Kingston area?
afennell
IMOC Organiser
Post by afennell »
think even if you do not have the upgraded sound system there is still a small toyota amp.
This will need a remote wire to turn it on before it will work.
Sorry can't help anymore.
fearless
Post by fearless »
you know what afennell you could be right :-k that would explain why none of them work. i tested stereo on another speaker just in case i was sold a duff unit from ebay, but all outputs worked fine wiring diagram ive been looking at is for a uk & european and aussie car with premium system 1 sub but i dont have sub. theres a red and black wire but that states on the wiring diagram that wire is amp power control what do you think should i connect this to blue remote wire off back of stereo the one you use to power up amps. i think it carrys about 3 volts if i remember rightly. ive fitted loads of stereos last car i had done install myself 2 amps 15" sub all the nice fuses and a power cap looked the nads and im stuck big time with this very annoying for me have to try after work tomorrow if it stops raining that is :thumleft:
afennell
IMOC Organiser
Post by afennell »
Give it a go, even if it is the wrong wire you will only be connecting it to a speaker wire so nothing to worry about.
I had the same problem with my first rev1 mr2. The stereo wiring was a mess.
Is you Arial going up, think that needs a remote as well.
Stick with it you will get it going and it will feel great. :thumleft:
StuartLaws
Arial and Amp are both connect to the blue wire from my stereo, arial works and there is sound.
fearless
Post by fearless »
managed to get sound today but only connecting one wire. i thought you needed a positive and a negative to run a speaker weird. weathers to crap tonight and struggling to see as it is dark have another go later if not into the stereo shop next week i give up thats £30 i could have had towards another mod. bummer might have another go i hate spending money on things i can normally do myself ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,) ](*,)
fearless
Post by fearless »
right really getting the ar$e now thought i would start again. got old radio that still had plug on it plug has these wires atached to it
brown wires x 2 quite (thick)
red wire quite (thick)
purple wire (thin)
grey wire with (blue line quite thin)
brown wire (red line quite thin)
dont know if this is standard radio for car or someone bodged it in im thinking red to live one of browns is the earth and thin blue/grey wire and red/brown wire could be speakers and brown thats left could be earth for speakers leaving maybe purple for electric ariel if someone could shed some light it would be apreciated many thanks steve
frogmk2
Post by frogmk2 »
Had a similar problem in mine.
If you have an active system (sub behind passenger seat) then there are NO negative speaker wires to the Headunit, they are earthed through the amp.
The best thing you can do is re-wire the car, just use the live, switched live and earth from the cars loom and wire the speakers direct from the head unit
BLZ-8027
Post by BLZ-8027 »
nofearmadbiker wrote:right really getting the ar$e now thought i would start again. got old radio that still had plug on it plug has these wires atached to it
purple wire (thin)
Hi
My car is a 1990 G-Limited with the active system ,but only one sub behind the passenger seat , and a single white plug behind the dash ,and with the AM aerial running down the windscreen
I have fitted an aftermarket stereo using the aftermarket loom adapter as can be bought for the active system (cant remember the part number ) This is how the wires relate to each other from the car, to the adapter and stereo
CAR STEREO
red with silver dots FRONT SPEAKER(RCA)
blue with silver dots REAR SPEAKER (RCA)
brown with silver dots REAR SPEAKER (RCA)
yellow with silver dots NOT USED (BEEP)
white with silver dots FRONT SPEAKER (RCA)
black with silver dots TELEPHONE MUTE
green with silver dots (center of plug) LINKS THE EARTH ON SPEAKERS
brown with silver dots (thicker wire) EARTH
blue with brown stripe and silver dots LIVE
green with silver dots (one side of plug) NOT USED
pink with blue stripe and silver dots AMP REMOTE (needs live)
black with red stripe and silver dots ANTENNA PERMANENT
white with green stripe and silver dots NOT USED
Grey with red stripe and silver dots FUSED LIVE
In summary one side of the plug is the power and the other is the speakers , my speakers didn't work at first until i fed a live feed to the AMP REMOTE ,but i recommend this feed to be switched otherwise you will get a loud thump from the speakers as soon as ignition is switched on,And i used to get a constant buzz from the amp even without the stereo turned on due to a permanent live feed to the amp
Your stereo wires might differ from mine though and this is only a guide as to how mine is wired.
If it works for you might be worth making it a sticky for future reference hope it helps ?
fearless
Post by fearless »
thanks matey car went in today and stereo was fitted charged me £65 but i have choons now thank god. was doing my head in nice kenwood just sitting on my table thay bypassed amp and ran speakers from amp from what i can see. anway i have nice fat oxygen free cable least its easy now when i want to upgrade stereo gutted i had to cough up. that would have bought me my toms scoop nevermind :( :(
Return to “Electrical”
