Paul Woods wrote:toyota only as far as i know,ive tried to get them elsewhere myself and failed.Personally i dont see how a mk1 oil cooler can work given that the coolant flowing through it is hot,probably hotter than the oil its supposed to be cooling.Ive bypassed the oil cooler on a few mk1's that ive fitted corolla engines to with zero side effects,its one of those toyota extravagances thats not really needed in my opinion.So if you have one good oil cooler pipe and you need to stop a leak you can link it from the top hose to the bottom and bypass the cooler.
