[Mk2] [Turbo] help with diagnostics
davelowe78
Post by davelowe78 »
have a bit of a boostprob and tryed to do the self test with the old paper clip but the engin light just stays on and wont flash it should flash even if all is good but mine wont flash at all can any one help and before any one asks am putting the clip in e1 and te1 :(
ChrisW
Re: [Mk2] [Turbo] help with diagnostics
Post by ChrisW »
Have you got the key in the 'On' position and your immobiliser disabled?
davelowe78
re
yea just as it says i have done the check in the past and it worked fine, cant understand why this happening????
ChrisW
Post by ChrisW »
Don't know what to suggest other than try it again, sometimes you need to push the paperclip down a bit further or give it a wiggle to make a good connection.
davelowe78
re
tryed that 2 cheers for trying mate
jimGTS
Post by jimGTS »
fact is you havent connected it correctly dude.
you just need to keep trying and use other clips or a bit of wire.
3S Service Centre
Post by 3S Service Centre »
the bulb could be duff or have been removed.
jmachling
Post by jmachling »
davelowe78 wrote:...the engin light just stays on and wont flash...
3S Service Centre - brilliant with everything 3S-GTE, just not so good with reading :wink: :lol:
(j/k - don't kill my car next time I come to get something fixed :pray: )
jmachling
Post by jmachling »
On a more helpful note, though - you are putting the wire in with the ignition off then turning it on?
I'd say pull the fuses and reset it, but that kinda defeats the object of looking for the codes as they'll be reset.
3S Service Centre
:mrgreen: sorry dumb moment must slow down :mrgreen:
davelowe78
re
been pookin the clip rite in and still nothing the bulb is ok as tjhe light comes on but just stays on ????
Merlin
Post by Merlin »
you bridge connections right on the ecu, if this fails to work you probably have a faulty ecu
Rob from 3s
