I've run these cars on water only
(no coolant at all), a mix of for life and water and For Life
/ Long Life
(or Halfords brand ethylene glycol based) coolant only
(not tainted with water) and have not had a problem with the cars overheating.
Only issue you will have using water only long term is a buildup of scaling and rust which could block the system leading to other faults worst case.
Topping the system up with a little water is quite perfectly fine.
What you really want to avoid though is mixing alcohol based coolant with Ethylene glycol based
(long life/for life) coolant
- it will turn to jelly pretty rapidly.
