error codes
error codes
fitted a apexi air filter on a mr2 turbo and now i get 2 error codes 24 and 31 any ideas
Re: error codes
Plug your AFM back in, those codes are for the intake temperature signal and the airflow signal, both come from the aiflow meter box, im assuming you havent removed it, if not plug the connector back in and reset the ecu by pulling the EFI fuse in the engine bay fusebox for 30 seconds
Graeme
Graeme
