Replaced the dizzy and the rotor arm after missfirings and idling problems but the problem continues.
.its like I never even replaced these parts.
.and my old dizzy and rotor were really knackered too.
plugs only a year old.
Heres what happens
: The car on cold start up will idle low at 950-1000.
.not 1500 like it
should.
It'll stay like that for around 30sec.
Then there will be a wierd
"brrmp brrmp brrrmp" sounds interrupting the steady
"brmmmmmm" of the engine and the idle judders about with this sound
If I tap the throttle there is a clear delay befor the revs will respond and it has a lot of trouble settling down again.
Eventually itll conk out as the above mentioned
"bbrmmp brrmp" takes right over and the engine stalls.
Ive checked the hosing they are all fine.
Ive yet to put in the redex stuff
(car ran very low on fuel recently might be clogged injectors im thinking).
