New custom droplinks
has n e one purchased the new custom droplinks from the twos r us shop and did they make much difference, i recently fitted new 40mm pi lowering springs on standard struts and this has caused a lot of knocking on bumpy roads and i was wondering if i purchased the new droplinks it may help silencing the knocking???
Re: New custom droplinks
MORE INFO NEEDED MATEY
DOES IT KNOCK ONLY WHEN YOU GO OVER BUMPS IN THE ROAD??
HAS ALL THE SUSPENSION PARTS BEEN PUT BACK TOGETHER TIGHTLY AND SLOTED IN TO THE CORRECT PLACE??
AS THE TOP DISH THAT SITS ON THE TOP OF THE SPRING HAS A SQUARE LOCATER, TO LOCATE ITSELF ON THE STRUT.
DOES IT KNOCK ONLY WHEN THE WHEEL IS TURNED, IF SO DOES IT STILL KNOCK WHEN PARKED UP AND THE WHEEL IS TURNED??
CHEERS
RICH
CHEERS
RICH
Rich
Stop SHOUTING mate
Stop SHOUTING mate
Alex_Dunn wrote:has n e one purchased the new custom droplinks from the twos r us shop and did they make much difference, i recently fitted new 40mm pi lowering springs on standard struts and this has caused a lot of knocking on bumpy roads and i was wondering if i purchased the new droplinks it may help silencing the knocking???
Could be coil clatter,this happens when the coils of the lowering springs hit against each other when going over bumpy roads.I had this when I used lowering springs,got fed up with it and changed to coilovers
Watch out OZ here I come
Andy F wrote:Rich
Stop SHOUTING mate
Sorry dude in work and not meant to be on the internet had to be quick!
sorry
Rich
yep bought them, the only advantage was no more hex key when bolt an unbolt and no more leaky boot
, in theory if you lower your car the bar where drop link link to will be lower so harder to knock
? and are you sure you line up the top mount correctly
?? I know it will fit any direction but only only way is the correct follow the dot on the top mount otherwise it will knock when driving
i had a knocking noise and i found tightening the bracket that holds the spare wheel sorted mine
i think warn bushes can cause knocking? your car a high millage alex? could be suspension bushes.
