[Mk2] [Turbo] What's these?
C50
Post by C50 »
Does anyone here know what dump valve i've got? Is it a particular brand? Its given off a turbo chatter and i would like to stop it as i want my turbo to have a long prosperous life :?
Also my strut brace, is it el cheapo?
I like to know what's currently on my car.
gnzyza
Re: [Mk2] [Turbo] What's these?
Post by gnzyza »
Not sure what type maybe some else can tell you.
But it does look like the spring tension can be adjusted so just loosen it off a tad to get rid of the chatter worked on my blitz
C50
Post by C50 »
Tried that but the nut just comes off instead. Cant really afford to buy another dump valve.
karammander
Post by karammander »
strut brace looks like one of the cusco range, they had two i believe.
when do you get this chatter is on light throttle or full boost let off?
cheers karam
-:[KM]:-
Post by -:[KM]:- »
C50 wrote:Tried that but the nut just comes off instead.
Loosen the nut and unwind the stud with an Allen key quarter a turn at a time (anticlockwise!).
It should relieve the spring, therefore the pressure it will blow off at.
:wink:
gnzyza
Post by gnzyza »
Yup exactly what KM said, the nut is there to keep if from turning once set. loosen screw type thingy with an allen key only a little at a time and then try until you get the right tension and then nut it up to make sure it doesn't move.
C50
Post by C50 »
karammander wrote:strut brace looks like one of the cusco range, they had two i believe.
cheers karam
I thought it might be a cusco coz of the coloured ends.. just i saw a chunkier cusco one.
I get the chatter on both.
Undid the screw fully and still get it :mad:
gnzyza
Post by gnzyza »
I dont know the tubby as most on here so hopefully someone else can give a better reply.... but you definately should NOT be getting chatter when coming off full boost. one thing it can be is the bov is seized, you can take it off and see if with a abit of pressure the piston should go back and forth. if it doesn't then its seized.
Can anyone else add to this???
C50
Post by C50 »
I've taken it all apart gnzyza. I think it's a push type dump valve. Cleaned everything, nothing is siezed :-k
I've tried minimum tension but car was a bit 'stuttery' and still had chatter so had to increase tension a bit.
Hmm.. i'm puzzled but cant really afford a new one :(
mark239
Post by mark239 »
ny arc DV makes that noise too - a tissh then a flutter.
that does look cusco coloured that strut brace - mine are the chunkier ones. Pic before i removed all the breather hoses:
