Dang, good point.
I've dug out the info I have on NGK Plugs from a post to the old US Email list
(Hmm, I need to buy a set of BKR7E's)
FWIW, I gave a set of 7ES's to a friend with a Rev1 and his engine really didn't like them.
Part
#6097
: BKR7E Stock
#: 6097
£1.43
£1.68
(not in stock)
Part#4930
: BKR6E
- 1.53 ea
inc
£12ish all in
(stock heat range, with resistor)
Looking back through the archives, others have used:
(resistorless)
Part
#5030: BCP7ES Stock
#: 5030
£ 1.16
Part
#: BCP6ES Stock
#: 4930
£ 1.01
The first digit in the NGK part number indicates the heat rating.
Lower numbers are hotter, higher numbers are colder.
Without trying to describe the whole NGK part number system, the above part numbers break down as follows, from first letter/digit to last:
B
- 14mm thread diameter
C
- 5/8" hex size construction
K
- 5/8" hex size construction, projected tip
(ISO)
P
- Projected insulator type
R
- Resistor type
(heat range 2 through 11)
E
- 19mm
(3/4"
)thread reach
P
- Premium platinum VX
- High-performance platinum
Y
- V-grooved center electrode
(14mm only) 2.5mm insulator
A
- Special Design
-11
- 1.1mm gap
-8
- 0.8mm gap For plugs with a flat seat and gasket
(all of the above, I believe), NGK recommends torquing 14mm plugs to 18.0-25.3 lb-ft in cast iron heads and 18.0-21.6 lb-ft in aluminum heads.
If you don't have a torque wrench they say to give it between 1/2 and 2/3 of a turn after finger tightness.
