If its idling rough then it could be because its only running on 2 or 3 cylinders, check for damp in things like the dizzy cap, and spark plug tunnels.
I jet washed my engine
(something i wont ever do again!!) and i got loads of water in the system, it all seemed like a really good idea at first, soon changed my mind! it took ages for the water to completely get out of the system, a good week or so with regular runs.
If it hasnt been done for a while, then its worth just changing the leads and plugs anyway, give it some tlc! Failing that, try moving the ht leats about and see if it suddenly perks up.
If you get no joy, remove one plug at a time, if the car stalls you know its a good one, if you get no change at all then its there.
Mike
