[Mk2] [Turbo] warning lights
cornyenty
Post by cornyenty »
hi all. can u help? just got in my car 2 nite and within 1 min of driving 2 lights came on.. so just turned around and went bk home.. not sure what theses lights are for.. 1 is batt not sure about the other.. anyway got some pics>>>>>>>
Ian Geary
Re: [Mk2] [Turbo] warning lights
Post by Ian Geary »
Hello mate,
welcome to IMOC and MR2 ownership.
The light on the corner is the catalytic converter temperature warning light. (There's a sticky thread in the mechanical forum I think).
Basically, it comes on when the cat gets too hot.
What should you do? Drive slowly to your local Toyota dealer.
What should you really do? Take off the exhaust flexi section, and have a look at it.
It could have slipped down and be blocking the zorst. Solution: new cat (expensive), gut the cat (free), or get a cat replacement pipe£100 - £200).
(note: if your car is +1995 you'll be limited by the MOT test)
Or, oil could be getting passed though your engine onto the cat and gumming it up. Does your car smoke on boost? Is there oil in the metal air pipes leading into the throttle body?
hth
Ian
cornyenty
Post by cornyenty »
hi. thanx for the reply. well cant see it getting 2 hot as i only went out for less than a min. but i have a new decat pipe waiting 2 be fitted. ive got a GT T Bar turbo 93 but on a L reg so waiting until my mot runs out in april..
Ian Geary
Post by Ian Geary »
A 1994 car should be well clear of the 3.5% CO2 test if it's running well - just make sure the garage test it properly.
I'm trying to recall if that light comes on with the ignition..?
Unless there's a fault with your circuit perhaps?
The sensor is screwed into the side of the cat, very low down. It plugs into the wiring loom in front of the intercooler, also quite low down.
hth
Ian
cornyenty
Post by cornyenty »
aready spoke 2 the garage about my decat pipe. said it will have 2 take a cat test being a L reg even tho its a 1993 rev 2.. but thanx for the info and try 2 get in the garage asap.
yes both light comes up when i start the car.. and stays on while driving.
im not mechanical minded so i dont have a clue what 2 look for.. plus its 2 dark at the mo 2 look..
cheers
iwantoneofthose
Post by iwantoneofthose »
cornyenty wrote:aready spoke 2 the garage about my decat pipe. said it will have 2 take a cat test being a L reg even tho its a 1993 rev 2..
i thought pre 96 turbo cars were tested as non cat as they are an import and have no model report or like for like uk car ?? think there is a sticky somewhere.
Edit:
Found it :D
http://www.imoc.co.uk/forums/viewtopic.php?t=43072
qual
Post by qual »
Just picked my non turbo up this morning and drove 70 miles fine,
Then the same 2 lights have come on and are staying on , bit concerned seeing as i have only just picked it up, Its running fine and not getting hot, the battery is in good condition aswell.
HELP, not a good start!
cornyenty
Post by cornyenty »
well it was my v belt what snapped. then my batt wasnt charging and finally had no power lefted.. got that sorted and the lights went off. hope that helps..
Slarty
Post by Slarty »
^^^^^ What he said.
Two or three lights coming on at once are symptomatic of a bad/low charge. Check the belt first, then the amount of charge getting to the battery. Use a multimeter to check the amount of charge getting to the battery, on fast idle it should be approx 14.4 volts.
hth :)
qual
Post by qual »
well its in the garage, and the noise i heard was the alternator belt snapping which is why the ligts come on, I've also ordered a decat pipe for it.
The radiators got a hairline crack in aswell.
oh well
