[Mk2] [Generic] Help fitting Ganador mirrors - connectors don't match
Edwin
Post by Edwin »
I thought Ganador mirrors were bolt-on? I've been fitting my new mirrors but noticed the Toyota connector is much smaller than the Ganador ones. Both have three wires so that should be the same... anyone else had this problem? What to do? I really don't want to cut off the Toyota connector on the stock mirrors in case I ever put them back on!
Grajey
Re: [Mk2] [Generic] Help fitting Ganador mirrors - connectors don't match
Post by Grajey »
That's the 7pin plug that connects to retractable mirrors.
I have the mirrors and loom, here, ready to fit.
HTH
Frederik
Post by Frederik »
Hi Edwin,
That car really looks stunning now!!! :thumleft:
Good luck with the mirrors.
Edwin
Post by Edwin »
Grajey wrote:That's the 7pin plug that connects to retractable mirrors.
HTH
Ah I see... mine is a GT-S so no retractable mirrors. I'll just try and solder something together then, unless you have a better idea? :?
Peter Gidden
Post by Peter Gidden »
Just cut and shut the plug off the old mirrors. Cheap as chips on ebay if you need to replace them.
Edwin
Post by Edwin »
Peter Gidden - SBITS wrote:Just cut and shut the plug off the old mirrors. Cheap as chips on ebay if you need to replace them.
Yes... you're probably right. And if I can solder the Toyota plug onto the Ganador harness, I can sure solder it back on if I want to. Cheers for that! :cheers:
Pizza-Tossa
Post by Pizza-Tossa »
You don't need to cut and solder, the pins are the same, depin and reconfigue into the old 3 pin connector to suit. If you can't do it then Rogue Motorsport can do it as they have a new elecronics/mapping guru who seem to know lots of tricks like this.
Ivor.
Edwin
Post by Edwin »
Pizza-Tossa wrote:You don't need to cut and solder, the pins are the same, depin and reconfigue into the old 3 pin connector to suit. If you can't do it then Rogue Motorsport can do it as they have a new elecronics/mapping guru who seem to know lots of tricks like this.
Ivor.
Even better! Thanks, will have a go at it tomorrow! Rogue is a bit off as I'm in Holland :mrgreen:
Harry
A1
Post by Harry »
Ivor.
2 :mrgreen: :mrgreen: 7 JAE \:D/ ...England
Edwin
Re: A1
Post by Edwin »
Harry wrote:2 :mrgreen: :mrgreen: 7 JAE \:D/ ...England
We'll be booking the ferry this month already! Will be a blast, we MUST do a photo shoot with the coolest super white mr2's there, don't you think? :D
ducatichick
Post by ducatichick »
I love your spoiler, who is it made by? It looks vustom-if so then 1000% spot on to you.
Oh (nice choice of 2 colour btw :whistle: 8-[ ) :mrgreen:
Edwin
Post by Edwin »
ducatichick wrote:I love your spoiler, who is it made by? It looks vustom-if so then 1000% spot on to you.
Thank you :) The wing's not custom, it's made by Do-Luck and VERY rare! More pics available here:
http://www.carpron.com/multisite/v/Uplo ... rl/Bodykit
