Cams.
Supercharged89dude
Cams.
Post by Supercharged89dude »
Anybody ever do cams in the 4AGZE? I was thinkiong of caming the car since i decided to do the head gasket and timing belt. Any info would be great.
crazylegs
Re: Cams.
Post by crazylegs »
you should have mail.
Supercharged89dude
Re: Cams.
What cam would u suggest? Basicly my step pops and I want to make it so u have to pay attention eveery second u drive this car. Once i have the initial inspection, which will happen very soon, i dont care if it wont pass next time. MY exhaust is going to be the TRD header, to custom exhaust that is just going to come down from the header right to a 6 in. glasspack that will then go right to the rear of the car. Probably 2.75" piping. Anyhow, I want a very aggressive cam. I want the idle to sound rediculous.
Supercharged89dude
Re: Cams.
More duration will make more trq on the bottom end right? So lift will make more power at the upper end right? Car is SC so I think i wanna go with a more upper end power cam. I figure the SC will provide the trq for the lower end.
Brand Part # Grind # Gross Lift Valve Lift Adv Dur Dur @ .050" Timing Valve Open Valve Close Valve clearance Notes
WEB 45-082 294 8.178 mm 244º 218º 105º I / 107º E 4º I / 36º E 34º I / 2º E .15mm I / .20mm E New Cam
WEB 45-182 577 8.382 mm 252º 226º New Cam
WEB 45-091 101 8.890 mm 250º 228º 105º I / 107º E 9º I / 41º E 39º I / 7º E .15mm I / .20mm E Hard Weld
WEB 45-021 119 9.753 mm 276º 240º Hard Weld. Under bucket shims
WEB 45-071 110 10.033 mm 284º 256º Hard Weld. Under bucket shims
WEB 45-131 286 10.109 mm 257º 226º Hard Weld. Under bucket shims
Stock 8.636 mm I / 8.788 mm E 255º I / 258º E 206º I / 204º E Specs supplied by Crower
Stock 13501-16030 7.10 mm 232º 8º BTDC Intake. 4A-GZE & small port 4A-GE
Stock 13502-16020 7.10 mm 232º 47º BBDC Exhaust. 4A-GZE & smallport 4A-GE
Stock 13501-16010 7.56 mm 240º 111º 9º BTDC Intake. 4A-GE large port
Stock 13502-16010 7.56 mm 240º 111º 51º BBDC Exhaust. 4A-GE large port
Crower 61821 9.194 mm 268º 216º I / 220º E Street use, slight lobe at idle, 1500 - 6500 rpm
Crower 61822 9.982 mm I / 9.982 mm E 276º I / 280º E 220º I / 236º E 4A-GZE,1750 - 7250 rpm
Crower 61823 9.982 mm I / 9.65 mm E 284º I / 288º E 230º I / 230º E Race. rough idle, 2000 - 7500 rpm
Crower 61824 9.652 mm I / 12.522 mm E 288º I / 294º E 230º / 236º E Full race. 2500 - 8500 rpm
TED Stock AW11 Master 7.56mm 240º n/a OEM 1985/86
TED KK109 7.56 mm 256º 214º Regrind. Same as TRD cams. +10hp
TED KK115 7.70 mm 276º 224º Good power on stock engine. +20hp
TED KK106 8.20 mm 312º 264º C Sports Racer
TED KK294 8.20 mm 244º 228º Great street drop-in. Same as WEB 294
TED KK114 8.80 mm I / 8.65 mm E 272º I / 266º E 244º I / 238º E Biggest with stock ECU. Japanese race grind
TED KK104 8.30 mm 304º 250º Same as TRD / HKS
TED KK113A 8.65 mm 304º 250º Great street / strip racer cams
TED KK107 8.65 mm 310º 264º
TED KK102 9.70 mm 262º 232º Same as TRD rally grind. Stock ECU + injectors
TED KK329 9.75 mm 306º 274º Race only. 4000 - 9000 rpm
TED KK108 10.35 mm I / 10.00 mm E 264º I / 258º E 236º I / 230º E Most torque for street / strip. Stock ECU + lifters
TED KK103 10.35 mm 304º 254º Race. Shim-under lifters. Same as HKS
TED KK112A 11.50 mm I / 10.40 mm E 286º I / 292º E 258º I / 254º E Shim-under lifters.
TED KK111A 11.15 mm I / 11.10 mm E 320º I / 304º E 270º I / 260º E Race only.
TED KK110A 12.45 mm Unknown Unknown Higest torque. 4340 steel billet
TED KK100/101 11.00 mm I / 10.80 mm E Unknown Unknown Atlantic spec
HKS 2202-RT030 7.45 mm 248º
HKS 2202-RT031 8.35 mm 256º
HKS 2202-RT032 8.35 mm 264º
HKS 2202-RT033 8.35 mm 272º
HKS 2202-RT034 8.30 mm 288º
HKS 2202-RT035 10.35 mm 288º
HKS 2202-RT036 8.30 mm 304º
HKS 2202-RT037 10.35 mm 304º
TRD 13501-AE801 10.00 mm 304º 98º 62º BTDC .32 mm Intake. N2 & FA Rev to 10000 rpm
TRD 13501-AE811 10.00 mm 320º 98º .32 mm Intake
TRD 13501-AE851 7.50 mm 304º 100º 52º BTDC .20 mm Intake. Group A 4500 to 7000 rpm
TRD 13501-AE861 7.50 mm 288º 98º .20 mm Intake
TRD 13501-AE871 7.50 mm 272º 98º .20 mm Intake
TRD 13501-AE881 11.00 mm 320º 100º .32 mm Intake
TRD 13501-AE891 10.70 mm 304º 98º .32 mm Intake
TRD 13501-AE901 11.00 mm 312º 102º .32 mm Intake
TRD 13501-AE951 11.00 mm 304º 102º .32 mm Intake
TRD 13502-AE801 10.00 mm 304º 100º 76º BBDC .34 mm Exhaust. N2 & FA Rev to 10000 rpm
TRD 13502-AE811 10.00 mm 300º 98º I / 100º E 62º BTDC 76º BBDC .34 mm Exhaust. N2 Rev to 10000 rpm
TRD 13502-AE821 10.00 mm 288º 100º .34 mm Exhaust. Rev to 8000 rpm
TRD 13502-AE831 10.00 mm 272º 100º .34 mm Exhaust. N2 and Rally
TRD 13502-AE851 7.50 mm 304º 100º 65º BBDC .25 mm Exhaust. Group A 4500 to 7000 rpm
TRD 13502-AE861 7.50 mm 288º 100º 57º BBDC .25 mm Exhaust. 4000 - 7000 rpm
TRD 13502-AE871 7.50 mm 272º 100º .25 mm Exhaust
TRD 13502-AE881 10.70 mm 304º 100º .35 mm Exhaust
TRD 13502-AE901 11.00 mm 304º 102º .35 mm Exhaust
TRD 13502-AE951 11.00 mm 296º 102º .35mm Exhaust
Toda 02.TD.CS4AGOS1 7.90mm 256º
Toda 02.TD.CS4AGBF2 8.50 mm 256º Recommend use valve train kit, under bucket shims
Toda 02.TD.CS4AGCJ1 9.00 mm 256º Recommend use valve train kit, under bucket shims
Toda 02.TD.CS4AGCJ2 7.90 mm 264º
Toda 02.TD.CS4AGCJ3 8.70 mm 264º Recommend use valve train kit, under bucket shims
Toda 02.TD.CS4AGAI1 8.90 mm 264º Recommend use valve train kit, under bucket shims
Toda 02.TD.CS4AGOC2 7.80 mm 272º
Toda 02.TD.CS4AGOA2 7.90 mm 272º
Toda 02.TD.CS4AGOP1 8.50 mm 272º Recommend use valve train kit, under bucket shims
Toda 02.TD.CS4AGOB2 8.70 mm 272º Recommend use valve train kit, under bucket shims
Toda 02.TD.CS4AGAI2 8.90 mm 272º Recommend use valve train kit, under bucket shims
Toda 02.TD.CS4AGOP4 9.90 mm 272º Must use valve train kit, under bucket shims
Toda 02.TD.CS4AGCJ4 10.30 mm 272º Must use valve train kit, under bucket shims
Toda 02.TD.CS4AGOJ4 10.30 mm 280º Must use valve train kit, under bucket shims
Toda 02.TD.CS4AGOC3 7.80 mm 288º
Toda 02.TD.CS4AGOP2 8.50 mm 288º
Toda 02.TD.CS4AGOB3 8.70mm 288º Recommend use valve train kit, under bucket shims
Toda 02.TD.CS4AGOI1 10.00 mm 288º Must use valve train kit, under bucket shims
Toda 02.TD.CS4AGOC4 8.50 mm 304º Recommend use valve train kit, under bucket shims
Toda 02.TD.CS4AGOC1 10.50 mm 304º Must use valve train kit, under bucket shims
Toda 02.TD.CS4AGOT1 10.50 mm 310º Must use valve train kit, under bucket shims
Toda 02.TD.CS4AGOA4 10.80 mm 320º Must use valve train kit, under bucket shims
Kent T1602 7.95 mm I / 7.70 mm E 272º 110º 26º I / 66º E 66º I / 26º E .25 mm Sports 2000 to 7000 rpm
Kent T1604 8.79 mm I / 8.54 mm E 290º 108º 37º I / 73º E 73º I / 37º E .25 mm Super Sports 3000 to 7500 rpm
Kent T1606 8.94 mm I / 8.69 mm E 306º 105º 48° I / 78º E 78º I / 48º E .25 mm Race 4000 to 8000 rpm
Piper TOY16VBP270 7.70 mm 252º 16º I / 56º E 56º I / 16º E Fast Road 2000 to 6500 rpm
Piper TOY16VBP285 8.13 mm I / 7.88 mm E 280º I / 278º E 34º I / 67º E 66º I / 31º E Road / Rally 2800 - 7500 rpm
Piper TOY16VGPA1 8.43 mm I / 8.38 mm E 300º 44º I / 78º E 76º / 42º E Rally 3000 to 8000 rpm
Piper TOY16VGPA2 8.43 mm I / 8.38mm E 310º I / 300º E 51º I / 76º E 79º / 44º E Race 4000 to 9000 rpm
What should i go with?
MarcsMR2
Re: Cams.
Post by MarcsMR2 »
Try HKS 272s, while I had them fitted they sounded great and it was top end grunt
Idle was too rough for the auto box
Supercharged89dude
Re: Cams.
My car is a 5 speed. So would these cams be fine?
