I've got my clutch off today
does my one look worn?
www.pradbone.f2s.com/car%20build/DSCF0088.JPG
Cheers,
Paul.
Jayng wrote:Hi Paul,
Didn`t see your other post and that you have removed the engine!!
I did my engine drop in the comfort of a double garage and it seems that you have done it outside.I`m not
in the UK at the mo, but from memory it should be ball shrinking cold right now!!!
Paul, I salute you.
Just wait until you put that engine back in!! I put mine off for nearly a year and it took a good mate to give me a kick up the ar$e to get on with it.![]()
Good luck with the rest of the job.
