Hey guys
I have got a Greddy RS BOV, but i need an adaptor flange for it to fit in the stock location, anyone know where i can find one , im assuming itll be similar if no the same as the blotz and HKS items.
Any one know?
Mark
BOV fitting kits/adaptor flange
Re: BOV fitting kits/adaptor flange
i ave got exactly the same problem with my blitz bov the only one about i could see is
http://www.forgemotorsport.co.uk/conten ... ct=FMFK038
hope this is what ur after.
i need one of these but 50 squid seem a tad ott.
i just got one of those....top quality and fits so so so perfectly...
i had the crappy bailey cut and shut jobby before.....
if you order it from forge you'll get in in 2 days...i have to say really impressed
one thing thought that long silicone pipe they supply you with doesnt really fit
go down to a local welder,i.e.sheet metal workers or the likes(plenty about)remove the original dump valve,take the piping off(takes about 5 mins)then get them to weld 2" or so of aliminium piping into the hole,make sure you remember to get a lip around the end and hey presto...!uve now got the perfect bov fitting kit,cost me £15 and works better than ny kit u could spend £50 on,hope this helps.....!
mrtee wrote:go down to a local welder,i.e.sheet metal workers or the likes(plenty about)remove the original dump valve,take the piping off(takes about 5 mins)then get them to weld 2" or so of aliminium piping into the hole,make sure you remember to get a lip around the end and hey presto...!uve now got the perfect bov fitting kit,cost me £15 and works better than ny kit u could spend £50 on,hope this helps.....!
u got and pics of what u ave done?
have dificulty in downloading pictures into the computer at the moment,problem with software,if u have a picture phone then if u want u can pm me with ur no. and ill send you a couple of pictures of what ive done
