mr2 turbo revisons
mr2turbo117
mr2 turbo revisons
Post by mr2turbo117 »
right did a search but found nothing ( does anyone actually find what they are looking for when they use a search...... :cry: )
im wondering when the diffrent revsion came out, now correct me if i am wrong,
90-91 REV1
92-93 REV2
93-96 REV3
96-98 REV4
98-99 REV 5
is this correct :roll:
cheers
mattcambs
Re: mr2 turbo revisons
Post by mattcambs »
does anyone actually find what they are looking for when they use a search...... )
not really, no ](*,)
Quigonjay
Post by Quigonjay »
mr2turbo117 wrote:right did a search but found nothing ( does anyone actually find what they are looking for when they use a search...... :cry: )
90-91 REV1
92-93 REV2
93-96 REV3
96-98 REV4
98-99 REV 5
cheers
that is correct
L0rdMike
Post by L0rdMike »
Think you can get 89 Rev1's ;)
mr2turbo117
ok cheers guys as i have rev3 thats a 96 and just confirming that it was a rev3 and not a rev4, cheers
Leon.
Post by Leon. »
mr2turbo117 wrote:ok cheers guys as i have rev3 thats a 96 and just confirming that it was a rev3 and not a rev4, cheers
Double check the date with the tag on your selt belts to check date of manufacture...
Do you have airbags? Do you have turned and lacquered 5 spoke alloys if still stock? Do you have a steering wheel with 4 branches?
If your answer to all of those is no, it most likely is a rev 3
HTH :D
ff_mark
Post by ff_mark »
mr2turbo117 wrote:( does anyone actually find what they are looking for when they use a search...... :cry: )
I was trying to find out what versions came with ABS the other day, spent about 1/2 an hour looking and still never really found an answer. #-o
tubby_mr2
Post by tubby_mr2 »
quote""" does anyone actually find what they are looking for when they use a search...... :cry: )"""
hardly ever
Draven
Post by Draven »
I believe that the Rev 3 onwards had ABS.. :mrgreen:
DavidM
Post by DavidM »
Draven wrote:I believe that the Rev 3 onwards had ABS.. :mrgreen:
Strange, I thought I had a Rev 4 (made Dec 1995), so it's a Rev 3, which is no sweat. But I don't recall seeing an ABS light on the dash, so did all Rev 3's have ABS or was it just an option? Or has the bulb gone? What is the easiest thing to look for to confirm whether I have or have not got ABS?
EX Caribbean Blue 10th Anniversary 1996 T-bar
EX Black 1995 mk2 GT Turbo
NOW Audi TT V6 3.2 DSG 2004 Coupe
Grajey
Post by Grajey »
Roadsterman asked:
Answer:
The great big ABS pump in the front trunk.
DavidM
Post by DavidM »
I wouldn't know an ABS pump if it fell out of the sky and hit me :oops: Where abouts in the front trunk? And will it say ABS on it?
Leon.
Post by Leon. »
The ABS light only comes on for a couple seconds as soon as the car is started. Put the ignition on and it should be there too.
DavidM
Post by DavidM »
Leeroy
Definately no light.
Leon.
Post by Leon. »
Then you don't have it.
What happens when you slam the anchors on really hard? Lock up or judder like a mother ........?
DavidM
Post by DavidM »
Leeroy wrote:Then you don't have it.
Have locked it up on the odd occasion :wink: , so must not have ABS.
On this reckoning then not all Rev 3's have ABS
