[Mk2 NA] HELP?? AIRCON KEEPS BLOWING FUSE??
jones_2001_2000
Post by jones_2001_2000 »
Can any body help or point in right direction, every time put aircon on it blows its fuse, worked fine for ages now wont stop popping fuses, is there anything to look out for specific or any pointers to look for?? your help would be greatly appreciated!!! The cars a Mk2 G Limited on 1993 plate!
Thanks in Advance
User avatar
Scott Barton
Re: [Mk2 NA] HELP?? AIRCON KEEPS BLOWING FUSE??
Post by Scott Barton »
Is it blowing the fuses when you turn it on or after a short while?
Sounds like the compressor could be knackered. ie down to earth. Best bet is to take it somewhere mate.
jones_2001_2000
Yeah, blows as soon as you press the button to turn on, think that may be best bet to get garage to check out if theres not a common fault that occurs on most cars!!!!!!
Return to “Electrical”
