Any ideas?
I hope it isn't the pads moving under braking, they should fit ok shouldn't they?
Hmmmm
Hmmmm
reggie wrote:If the shims are missing, I would suggest that these are put back in anyway as they should be cheap items.
reggie wrote:I'm interested about the'locating springs'.
If these are the plates that hold the pad in place, they could be the source of your problems.
Are all of the pad spring clips in place and located properly?
