I've checked this site quite thoroughly and I've seen very similar questions asked but not often concluded
(so sorry if I've missed a solution somewhere)
My CDA-9853R unit is dead when connected to my G-Limited loom
- not even a whir from the inside when the ignition wakes up!
It was fine in my Probe.
All the wires in the Alpine loom match up to the colours in the existing loom just like the JVC head unit that I took out but the JVC works no probs.
It's
(the JVC) back in the car and powered for the moment but now I get no sound and my clock's reset!
I'll check the footwell fusebox tonight as the
'dome' fuse I checked this morning under the bonnet is fine.
I've no idea what gives
- all the connections are good, the red
& yellow
+12v
& the ground all match up and look fine.
The blue antenna
& blue/white amp power have been scotchlocked together by someone in the past so that when the JVC powers on it's remote antenna signal activates both the MR2's amp and leccy aerial.
That's the only thing that seems to not match up.
That and the orange illuminations wire which doesn't connect to anything.
To summarise:
The JVC unit was a bit pikey but worked fine via the MR2 amp.
I remove the JVC unit.
I connect the
'power' half of the MR2 loom into the
'power' half of my Alpine loom.
It matches colour for colour.
I connect the Alpine loom
& 4 phonos to my CDA-9853R.
I hit the ignition and I get a loud POP from the speakers but no power from the Alpine, no internal whir or a flicker on the panel.
Connections are all fine.
Look confused.
Take Alpine
+ Loom back indoors.
Put JVC unit back in.
JVC powers on and appears to run fine but there's no sound at all.
Search this site for info.
Notice that like in another post my clock has reset.
Post here for help.
Very frustrating.
I didn't have a multimeter to hand but surely if one headunit with the same connections
& connector works then power is getting to the loom/head fine?
'elp!
